Carden wing sheeting?
My Feedback: (9)
NC
Hi All
I am starting my 35% Carden Edge 540, it states you can either glue the sheeting together prior to glueing to the cores. Or tape sheeting together and glue with polyurethane glue to cores taped together, remove the tape and sand.
If I glue to cores with out glueing sheeting together, what type of polyurethane glue do you guys use? Or should I glue sheeting and epoxy to the cores?
Thanks in advance
Bill
Thanks in advance
Bill
I used Elmer's Contractor Grade Pro-Bond on my AW 29% Edge and it came out great. I did edge glue the sheets first, but was planning on the tape-together method on my Carden 35% which is due in next month. Apply a thin coat of glue to the sheeting, dampen the wing core with a damp cloth (not too wet, just damp, it needs moisture to foam) and apply. You have plenty of time for adjustments. Weight it down with all those old modeling magazines. Good luck.
Hall
Hall
Pro Bond
Use ProBond polyurethane glue from Elmer's. The black and gold bottle. If you chose to glue sheeting together first do it with Titebond II or similar aliphatic wood glue, then use probond to glue the wood to foam cores.
Experiment with the probond and some foam. It does not take much. Epoxy will work, but it is heavy.
Go to www.edge540.com
or www.extra330.com
Bob Hudson's page is very detailed on "How to's".
Also I recommend calling Dennis at Carden. He is great to deal with and will take his time to explain every detail.
Be sure before you start!!!!!
Jess
or www.extra330.com
Jess
