differences between revo 5308 and platinum
NJ
i just got a revo 5308 and wanted to basically convert it into a platinum. i want to lower my revo but dont know how. do i need to buy anything? right now the rear sags but that can be fixed. i want to lower it not make it sag. any input will be appreciated.
NY
RE: differences between revo 5308 and platinum
Shiny chassis, fuel tank,center diff, close ratio gears,twin brake, wheels / tires, traxxas 'tubes', sway bar kit, bump start engine, spring mount header, extendedrear a-arms, shocks, springs, oil, wing and alot of nick nacks. Just put the pro-2 rockers on and use the outer most hole for the pushrods. Then turn your shock collars up to lower it even more if you like.
