H9 80" Cap linkages
H9 80" Cap linkages
Just received my H9 80" Alitalia Cap and need some suggestions for linkages and horns. I have four Hitec 5925's for the Ailerons and Elevator halves and a 5945 for the rudder. I plan on doing a pull-pull for the rudder as the manual indicates.
What should I use for the hardware (rods, links, horns, pull-pull) and where should I get it?
Thanks in advance,
Dave
Thanks in advance,
Dave
My Feedback: (13)
AK
H9 80" Cap linkages
I went with what H9 recommends. Titanium prolinks, Rocket City control horns,rocket city ball links, aluminum servo arms. I think I ended up spending about $180.00 for everything including pilot. You could go with 4-40 rods and make your own links. One word of caution make sure that your low rate elevator set very low. The tail is very effective and I could get mine to snap at speed with applying full up elevator. I have since turned it down and it is very tame now.
