New Cylinder and Piston for my BJ55
MO
Ordered the M5 upgrade (Warehouse Hobbies) for my Blackjack 55 today. Will my needle settings still be the same as the stock setup. What can I expect from this upgrade?
RE: New Cylinder and Piston for my BJ55
I'd consider buying a tach so that you can judge your tuning efforts by the RPM's you are able to acheive.
I'd start with the basic carb settins as found in the Zenoah manual as they should be on the rich side. However, your best option would be to email WHH and ask what they recommend.
ORIGINAL: Dockman
MO
Yeah I'm sure a header, pipe, carb, etc. are to follow. I had already ordered a X472 prop from Fun Rc.
ORIGINAL: PEERPSI
<div>I can absolutely guarantee it will lighten your wallet along with all to come.</div>
MO
This boat came with a 3 blade VooDoo prop (not sure what size). Are the 3 blades a better way to go? I' am an x dragboater racer and 3 blades were a no no.
The blade number should be somewhere on the hub. I just got a 3 blade stainless steel from Dasboata 7015. That was his recommendation.
MO
No number on the hub. The guy said it was a special order from Bonzai sport. He said put it on it runs 8 mph faster I will have to see that to believe it.
That's possible. I went from 34 to 40 by installing a 2714 3 blade chopper. That blade was meant to run with the stock motor. The new 7015 is slightly bigger and a little more pitch to run with the pro mod CC engine.
ORIGINAL: illiniboater
I recently did the M5 kit as well but have not ran the motor yet. I did see a Rio a few weeks ago atour pond that had the M5 and it was very impressive. There were stock Rio's running at the same time and the differancewas night and day. Nobodyhad a gps so can't give yaexact mph but for the money I doubt you'll be disappointed.
ORIGINAL: Dockman
Daniel
ORIGINAL: danielplace
How could you even compare a Zenoah even stock to a FUJI engine?There is none. If you said stock Zenoah powered BJ to The M6 it might have meant more. But good to know nonetheless.
Daniel
ORIGINAL: Dockman
Daniel
MO
A buddy of mine is high bidder on a Hydro on ebay as of right now. The boat has a Fuji 28 and I'm geussing that's not a good thing? Nothing I can do about it now bidding is in.
MO
Got the new cylinder/piston installed this week. Watched Tony's (Full throttle RC) video on tuning the carb last night. I have the low speed tuned and am ready to lake test it. Engine fires right up and seems to idle good, will test it later this week sometime?
If you adjusted it on the stand without the prop in the water it will be too lean. Did you ask WHH about the best settings to start with?
It's a zenoah clone. Not many good things said about them. Aqua Craft is the only company that I know of that uses them.
Maybe it was made by Fuji, never heard that.
Daniel
ORIGINAL: Dockman
Dockman, I think you will be happy with the M5 from WHH, for the money Tony does a good jod. I have one and have been very pleased. So I decided to get the M6 and it performs very well, have had no problems with either one.
Good luck;
Good luck;
The Warehouse Hobby engines run pretty good without breaking the bank. Tony has great service and really cares about the customer.
Daniel
[/quote]
Daniel
[/quote]
MO
ORIGINAL: PEERPSI
MO
I believe 644 carb should run at close to 1 1/2 L and 1 1/2 H. The needles usually need to total 3. I would go a little rich then observe the engine sound and read the plug.
ORIGINAL: Dockman
MO
While running the boat last night I flipped it over. Now the servo's are wet, so I have the back off of them and everything out of the box hoping they will dry out and be ok???
MO
Ok 2 servo's survived and 1 did not. Do I have to replace the bad servo with the exact samething or can it be any servo? All my stuff is stock Pro boat servo's and reciever. It's not the reciever I tried both servo's on both sides of the steering and the 1 servo does not work.
