Those damn stickers
I've had great results with getting them good & warm with my heat gun (of the type used to shrink the covering) and then carefully peeling them off, then using 90% rubbing alcohol to remove the glue residue.
For instance, here is my Escapade naked, with just my AMA number showing, with all of the factory applied stickers removed using the above method.
