carb
MB, CANADA
carb
Why is my carb stuck? I cant even put where the linkage goes on, its just stuck. I have broken the throttle linkage. but i just want to know is why its stuck???[&o]
RE: carb
I had that problem once. If you look inside the carb (based on s25). The slider has a groove cut into it. I'm not sure but I think it dictates the travel of the slider and has to be in a certain position for it to travel properly. Even when I eventually got it to travel in a straight line it still never recovered fully and would from time to time become stuck.
OH
RE: carb
if you broke your linkage during a bash session..chances are you have bent the carb itself where it slides.
Happened to me on my collari 32.
Take the carb off and FORCE it open/closed...be sure you remove it from the engine 1st so no metal shavings fall into the mill.
It can work again,but your best off getting a new carb.
CS
CS
RE: carb
To be honest, the slider first locked up rocked solid and would not move at all. Then by chance I managed to move it quite easily into place and all seemed well until it started to play up again. I didn't want to take the risk of it locking up whilst I was driving the car so i went and bought a new carb instead.
RE: carb
Here is a link, but you'll have to use a currency convertion page to work it out in CAD.
http://cgi.ebay.co.uk/NEW-HPI-SAVAGE...QQcmdZViewItem
MB, CANADA
RE: carb
So, i've just pulled my engine off the CHASSIS, i've pulled out the needle and still moving[&o] anything i can do so i dont have to buy a new crab, because im only 12.
RE: carb
Try calling HPI. They have been known to replace broken parts. If not, you're no worse off than you are now.
Also a carb off a Mach .26 will work great, it's actually a better carb, and it's usually only about 1/2 the price of a stock HPI carb.
RE: carb
They're not that different in price on e-bay. The Mach is a better carb though.
http://cgi.ebay.com/HPI-1462-Slide-C...QQcmdZViewItem
http://cgi.ebay.com/DYNAMITE-DYN0909...QQcmdZViewItem
Still, I'd call HPI before I bought anything.
MB, CANADA
RE: carb
Okay, So I've talked to HPI and they'll send me a free crab and they'll pay shipping, but im in Canada and it would have to go to customs, does anyone know the rate at customs right right
ON, CANADA
RE: carb
ORIGINAL: SavageXF4.1
theres no charge hpi will pay it all.
had a few item warrantied myself
reciever/tvp's/fuel tank.
