what are some other hop ups
My Feedback: (12)
WI
i all ready have, hump pack, different set of wheels, new shock springs, motor saver airfilter, dual disk breaks, new body, i think that is it..... ohh the 4 gear diff mod too, is there anything else that i can get?
MB, CANADA
RE: what are some other hop ups
get aluminum parts like A arms or shock towers, or graphite parts like an upper deck, or get a new motor if you have enough cash
WOW, I HAVE A CLUE,
GET THESE:
SH 28
STEEL SPUR
HARDENED CLUTCH BELL
POSSIBLY A 3 SPEED
ROLL CAGE (RCSOLUTIONS OR HARD BOYZ)
ALUMNIUM SHOCK TOWERS
METAL GEARED SERVOS
HUMP PACK
RECIEVER AND RADIO
AND THATS REALLY ABOUT IT ON THE NEEDED STUFF (OFF THE TOP OF MY HEAD)
IF YOURE INTERESTED THEN EMAIL ME AT [email protected] AND ILL SHOW YOU WHERE TO GET THESE AT ROCK BOTTOM PRICES
GET THESE:
SH 28
STEEL SPUR
POSSIBLY A 3 SPEED
METAL GEARED SERVOS
HUMP PACK
RECIEVER AND RADIO
Defintely center skid plate and failsafe. A 3 or 4 shoe clutch with aluminum pads.
Although I am not very experienced, I don't think the metal spur gear and hardened clutch bell are neccesary if the mesh is set up right. From what I have read, some people end up getting a super strong spurgear after the plastic one strips or breaks ( due to bad mesh), then the stock clutch bell gets damaged because of working with a superstrong spur and bad mesh). I also fell for the aluminum shocks but readread it is better to have the stock nylon ones.. so you have the plastic rubbing against metal spring instead of metal on metal. Apparently there is supposed to be less friction and they work better. If you do get some aluminium ones do NOT get the hot bodies. I have
Broken the seal on 4 of them so far. I am sure the other 4 aren't far behind. What is the graphite upper deck.. I think I want one
NC
Titanium turnbuckles, try a ribbed pipe too i guess they work good with the .25 motor if thats what your running, i have one on my hyper .21 thing is a monster, but they are a loud pipe.
