stuck in first
BC, CANADA
stuck in first
Hey there, i just replaced my two speed with a three in my Xss. I took it out for boot and it seems like it stayes in first gear?? Anyone have any suggestions on what the problem might be?
thx RR
thx RR
RE: stuck in first
ORIGINAL: RaceRocks
thx RR
thx RR
what i suggest you do before adjusting anything is hold the truck up off the ground and slowly pull the trottle trigger fully open on your transmitter and listen carefully for the shifts.
RE: stuck in first
Retune the carb....it's mandatory after upgrading to the 3spd. The gear ratios are altered enough to where the prior tune is not going to work that well. Never adjust the shift points until you retune the carb or else you will just create major headaches for yourself. After adjusting the carb you may find that you do not need to change the shift points-I've never had to adjust the 3spd's shift points. Just like you never adjust the carb's LSN to set the idle speed, you never adjust the trans to compensate for a mal-tuned carb. Also make sure the slipper nut is tight.....a loose slipper will prevent any shifting from happening.[8D]
