Re: Gunk On Plane
Re: Gunk On Plane
Old 02-11-2003, 09:32 AM
tkigar
Default Re: Gunk On Plane
Help, I need advise on how to get old gooey fuel off the side of a 15 year old plane? I have tried windex, and 409 but nothing is working. it has what looks to be monokote or ultracote. It is pretty thick material for covering not thin and cheap. Got any ideas on how to make this plane look pretty again without having to re-cover? Thanks Tim
Old 02-11-2003, 11:36 AM
BigBird1
Try WD40..then follow with soap and water....that should cut the gunk...then use a good wax...like Turtle wax....
Try in a small area first....
Old 02-11-2003, 01:44 PM
Cactus.
Cactus.'s Avatar
baby wipes work surprisingly well
Old 02-13-2003, 05:19 PM
Deadeye
Deadeye's Avatar
Starting fluid.
Old 02-13-2003, 09:59 PM
blvdbuzzard
If the gunk is from the oil in old fuel try Denatured alcohol. It will cut right through the gunk.
Dru.
Old 02-14-2003, 12:09 AM
Sense963
My Feedback: (10)
Sense963's Avatar
Wax? I've done that once/twice... Anybody regularly wax their baby? Does it help with cleanup or anything??
Old 02-14-2003, 01:51 AM
BigBird1
Pledge does wonders...for quick clean up
Old 02-17-2003, 04:33 PM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Default are you sure it's monokote?
If you're sure it has Monokote or similar, I'd use Lacquer thinner,
It cuts just about anything and won’t hurt the monokote except for a little dulling.
Then, Yes use some regular car wax, or Maguire’s plastic polish to give it that new plane shine back,
I wax all my planes (Painted or monokote covered) at least once a year, to keep them looking nice, and yes it makes the clean up easier.
Old 02-17-2003, 05:27 PM
RCaeroguy
RCaeroguy's Avatar
Dow scrubbing bathroom cleaner. The one with the little scrubbing bubble guys on the commercial. "We work hard, so you don't have to."
Old 02-20-2003, 04:01 PM
david a
I don't know if the advice you all are giving is just for Tkigar's particular problem or if the same goes for general use after a flight. I've used 409 and Windex to clean the oil and goo off my plane after a flight with mediocre results. The Windex seems to work better than 409, but it still smears the oil around at first rather than picking it up. It takes a lot of paper towels to get the oil off. Is there something I can use as a "Pre-cleaner" to remove most of the oil prior to using the Windex? My plane has Oracover on it.
Old 02-20-2003, 04:45 PM
CHassan
My Feedback: (13)
CHassan's Avatar
I use an old rag for after flight cleaning, then at the end of the day I break out the windex and give it a good going over. I do on occasion use a liquid wax on them. Don't know if it does a BUNCH of good, but it does make it shine and gives me piece of mind.
Old 02-20-2003, 05:10 PM
Deadeye
Deadeye's Avatar
I can't stress enough how well pressurized starting fluid works, guys!!! Give it a try!!!! Please!
Old 02-20-2003, 06:05 PM
david a
Do you get this stuff at Autozone or similar place and what's the name of it.
Old 02-20-2003, 06:11 PM
Deadeye
Deadeye's Avatar
I get 'Pyroil' starting fluid at NAPA, but any hardware store should carry it. It's $1.50 for 20 ounces. I can get 30 or so cleanings per can. I just saturate 1 Scott's shop rag after folding 4 times. That gives me 8 new cleaning surfaces. I hit the heavy stuff first, then buff to a high shine with the remaining 6 or 7 'new' cleaning surfaces. Takes less than 1 ounce to saturate a rag, and only 1 rag to clean a 60 size plane. Works like a charm.
Old 02-20-2003, 08:31 PM
smchale
My Feedback: (67)
smchale's Avatar
Default off the subject regarding gunk
OK, totally off the subject, I have some paper sticky gunk stuff on the back window of my new truck...how can I get it off? It's a factory tinted window and the gunk has come from the temp license tag i had to hang in the window. when i took the tag of i was left with 2 parallel lines of gunk.....for the lack of a better word.
Old 02-21-2003, 11:31 AM
RCaeroguy
RCaeroguy's Avatar
The best stuff is the Dow bathroom cleaner.
