Cylinder Gasket Material
Old 01-18-2013, 05:09 PM
All Day Dan
All Day Dan's Avatar
Default Cylinder Gasket Material
Can anyone identify this Mahle cylinder gasket material? It is not paper. It is black, about a 1/32 inch thick and is kind of rubbery. There is not enough of the white writing on it to read. I am using it in a Brison 3.2.Dan.
Old 01-18-2013, 08:01 PM
Lnewqban
Lnewqban's Avatar
Default RE: Cylinder Gasket Material
ORIGINAL: All Day Dan
Can anyone identify this Mahle cylinder gasket material?......
It may be Flexitallic (Flexicarb NR).
Check this:
http://www.flexitallic.com/products/flexible-graphite
Old 01-18-2013, 09:26 PM
w8ye
w8ye's Avatar
The chainsaw was a Dolmar 111 if you want to buy a genuine article.
You can buy the gasket material and cut your own at the auto parts store.
Old 01-19-2013, 01:22 PM
All Day Dan
Lnewqban, The shape of the logo is a perfect match to the gasket. You have a sharp eye. I’m going to see if I can find something like it in the auto parts stores in my area. Do you know of an on line source for the Flexcarb NR?
w8ye, I have the Dolmar gasket. It's good but this Flexcarb is much better.
Da n.
Old 01-19-2013, 07:42 PM
Lnewqban
Lnewqban's Avatar
Check with this distributor:
Industrial Gasket & Supply Company Inc.
23018 S. Normandie
Torrance, CA 90502
P: 310-530-1771
F: 310-530-9572
http://www.flexitallic.com/distributors/search
Old 01-19-2013, 07:44 PM
Lnewqban
Lnewqban's Avatar
Old 01-19-2013, 08:06 PM
w8ye
w8ye's Avatar
I have five Dolmar chainsaws and Brison 3.2 and 6.4's. They all have the gasket supplied with them and never any trouble.
Old 01-19-2013, 08:15 PM
w8ye
w8ye's Avatar
If I were you, I would measure the thickness of the existing gasket.
If you plan on using a different thickness base gasket you need to measure the squish or clearance between the top of the piston on the edge and the cylinder head in four quadrants. The desirable squish dimension is .020".
Adjust your base gasket thickness accordingly.
If no gasket use a thin layer of Yama bond or Honda bond as a gasket.
Old 01-20-2013, 12:45 PM
av8tor1977
av8tor1977's Avatar
Yep. What W8YE says.
I often leave out the base gasket when I hop up an engine, and have never had a problem using only Yamabond. When I do use a gasket, I make one out of the cover off a spiral notebook, file folders, cereal boxes, whatever has the thickness I want. Never had a gasket made this way blow out or leak. In fact, I had the cylinder get loose on one of my 30cc engines. (So THAT'S why it wouldn't idle down right on that last landing....) Anyway, the gasket was fine. I just cleaned and added Loctite once again to the bolts and reinstalled/tightened them, using the same gasket. Engine has run fine for several years.
Harbor Freight sells a great little kit of gasket hole cutters that is invaluable for making gaskets.
AV8TOR
Old 01-20-2013, 12:57 PM
acerc
acerc's Avatar
AV8TOR1977 does your wife give you the same look I get. You know something along the line of "What the shell is wrong with you, look"?
