Aeroworks 42% Ultimate balance, PLS HELP!!!
OH
Hello everyone,
I got little tail heavy. I drilled 1" behind the wing tube hole in the center top cabane. I measure from the backside of the hole and not the center. So the tail are heavy and I added about 4oz weight up front without Hatch cover. It balance pretty good and when i put hatch cover... then tail got a bit heavy... I am not sure if it's great idea to put 4oz or more weight up front? It got DA150 on it.. I tried to have everything up front to keep the nose down.
i measure the height of wheels when I hang it up... the front wheels's about 5 1/4" height from table and the balance with 4oz in front and hatch cover on, the rear wheel got 1 3/4" height from the table... without hatch cover, the front wheel's height's 5" and the tail wheel's height from table's 5 3/4", is that a good? or do I need to have nose more weight? I would appricate your help, thank u.
Ken
Ken
