Help
MO
RE: Help
Depends on many factors.
What wheel base do you want to run.
What chassis you are using.
What link plates you are using.
What set up, 50/50, 60/40,
And so on.
And so on.
NC
RE: Help
I will be using a stampede trans and axles for drive.I wanna run moabs(already got them).I dont wanna loose all my options but I already cut the bottom 28mm off the chassis.I need to get some recommendations lets say 11.5 inches to start.
Eric
Eric
MO
RE: Help
What chassis are you planning to use? The Pede and Stealth are both good w/ the Pede being easier for a noob to set up. Who are you using Stampede axles????
Some pics wpuld help.
NC
RE: Help
I took the stock plates and cut the bottom 28mm off below the holes. I am thinkin pede because of ease unless you can help me locate the axles/shaft I need for the stealth.
I will be able to pic in am but there is a site for a pic of what I did.
http://www.uk-microrc.co.uk/forum/in...showtopic=2748
scroll down to plates laying on table.
right above the yoke mod.
MO
RE: Help
Still didn't see a Pede chassis or axle. I think you meant TLT.
If so you can use these for your lower links along w/ some TRaxxas rod ends and it should but you in the ballpark.
http://www2.towerhobbies.com/cgi-bin...?&I=LXJVD7&P=7
