SAITO FG-14 spark plug
My Feedback: (8)
I bought a used SAITO FG 14B on RCU and it has a crack in the insulator on the spark plug, the thread is 1/4x32 and I hoped one of you would be kind enough to tell me the NGK replacement for the saito plug. Thanks for your help......any tips on the engine would also be welcome......Jim
RE: SAITO FG-14 spark plug
The design of the spark plug ignition cap requires that you use the Saito plug only. The wire keeper on the cap fits into a groove on the Saito plug to both retain the cap and provide the ground for the ignition. Othe brands of plugs do not have this groove and therefor cannot attache to the spark plug cap.
Saito plug part number is: SAIG20120
Pete
</p>
My Feedback: (8)
Thanks for your reply Pete, my ignition has a green ground wire that connects to the motor mount has someone added this to the ignition? I did buy this engine used and no experience with the Saito gas engines but have a couple of Saito glow engines. Thanks for any info you may pass on....Jim
ORIGINAL: bipeflr
Pete
Last winter we went to Florida. I had got a Ignition for a Saito 1.5 from Adrian. I was going to make a video while in Florida but a lot of unforeseen things happened, and never had a chance to make the video. I am back home now & finally getting caught up on honey due things. I will start the engine for the first time & see how she runs! Capt,n
My Feedback: (8)
Thanks for the link and info Capt'n but before I spend almost $200.00 on a new ignition I would like to test the one I have. However,I have a tester from Rcexl that has a Futaba or universel connector with three wires and the Saito has only a red and white wire with their connector.Is there another way to test the ignition? Thanks much for your help. ......Jim
ORIGINAL: bipeflr
There has been three different ignitions on the FG-14.
The first two are not compatible with anything RCEXL as they have an inductive pickup rather than a Hall Effect.
The third one is a re-badged RCEXL that has a special spark plug connector to fit the odd ball expensive Saito spark plug with the groove through the wrench flats,
A true RCEXL or a new CH ignition can be fitted to any of them.
