Is brushless system ever going to be cheaper??
They are expensive, sometimes enough to buy another car....
Are they going to be cheaper anytime soon??
RE: Is brushless system ever going to be cheaper??
I hope. When I go BL I plan on buying all remanufactured stuff from Novak. It's only about 70% of what the retail prices are.
ORIGINAL: Barber420
1 Post
They will come down in price just like every other new tech product does......Look at LCD tv's i bought mine a year ago and now its half the price for the same tv.
1 Post
ORIGINAL: samguan
what do you mean by remanufactured?
ORIGINAL: Barber420
Sure, 3-4 years ago it was $249. for an ESC and $99. for a motor. Today you can get a setup of similar power for $130. for both the motor + ESC. The trend will continue, especially with the relatively strong dollar and weakness in the PRC's manufacturing industry, etc.
It's already less expensive than it was a couple years ago. Of course the cutting edge stuff is still high but the stuff that was top of the line 2-3 years ago is more reasonable now. As more people adopt it, especially companies making vehicles that come with BL, it will continue to drop in price.
I was thinking the same thing. I paid $75 for an 80 watt brushless motor and $50 for a 10 amp ESC for my planes 5 years ago, now I can get an equivalent motor for $25 and the ESC for about the same. At that time I remember shopping around for car esc and motors and figuring it would cost about $400 to set up a decent 1/10 car with brushless. Now you can get a sidewinder combo for well under half that. I'm sure it will go down even more over time, but as the saying goes, "these ARE the good old days!"
HobbyCity.com. Thats where I get all my brushless and Lipo stuff. I Have 3 brushless boats and all are 25+mph and run great. Check it out. You will be surprised
You can get a sidewinder combo for $125 or cheaper. Its just when you add up everything like charger, motor, esc, and lipos it gets expensive.
At this time brushless systems are very expensive, as you know. Over time I'm sure that they will get cheaper though. The cheapest one I saw on Tower Hobbies website was $81.99. I think that, that is still a bit too much just for a motor, plus you have to include extra cost for the other accessories. That's why the way I went is an upgraded battery. Now this may not give the same performance as the brushless system will, but it will do, for a much cheaper price. The other thing about brushless is the installation, although for some people it may not be hard, and some people it will, but with a battery all you do is charge it and pop it in the car. Some good things about a brushless system is very low maintenance, and a lot of extra speed. Again, in this case I would go with the battery, and wait for the brushless systems to come down. At least in my personnel opion.
MI
I wish the major brushless manufacturers would focus on the maintenance benefits of brushless motors, rather than the performance aspects. While it's great that you can run 70+ mph with a high to middle level brushless, I'd rather have a dependable, cheaper brushless that's equal to mid level brushed motors, without the hassle of cutting combs, lathes, etc. I'm trying out one of the EZRun combos right now and if it stands up well during my bashing, I'll probably convert my other two Rustlers to brushless, especially since they run on both nimh and lipo batteries. No, it can't compete with Mamba, Sidewinder, etc, but I'm not expecting it to, especially at $80. What I like about it is that it IS faster than most brushed motors, again, without the maintenance.
If Sidewinder or Mamba came out with a sub $100 combo, I bet that would pretty much push brushed motors to the sidelines, except for the few of us that like running in water.
AB, CANADA
ORIGINAL: Cheap Guy
IA
brushless easily pays for itself in the long run if you play with your stuff alot, the cost is about 1/3 what it was five years ago and we got better stuff now, I suspect the knock off companies will eventually get around to escs but the hard part is the programming not the building, hundreds of people on this board could build one but I doubt if any of them could write the code and have it be smooth.
MI
ORIGINAL: Druss
I'm not quite sure on the revelance of the battery comment. Any brushed or brushless esc can use at least a 2S lipo as long as you have a LVC, either built into the esc or add on.
ORIGINAL: Cheap Guy
