Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
questions about Passport Mini P1 charger
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 05-08-2024, 01:38 PM
corneileous
corneileous's Avatar
Default questions about Passport Mini P1 charger
Hey guys, being that the charger that came with my well-over 15-year-old Traxxas Revo 3.3 was OK for charging the receiver battery, it really wasn't all that good of a charger for charging the EZ-Start batteries so, I bought this little Passport Mini P1 Charger to take that charger's place for the starter unit batteries. Worked pretty good. Even worked good for conditioning the batteries when they needed it....
Well, now that I'm getting more into Lipo technology, how will this little inexpensive cheap charger work for charging 5000 MaH and above 3S and 4S Lipos? Some day I'd like to get away from Traxxas batteries altogether but for now I'd just be using it to charge a non-Traxxas 11.1 3S lipo if this little charger can charge a battery like that in a reasonable amount of time. Thanks.
Old 05-13-2024, 02:56 PM
corneileous
Originally Posted by Tondo
It’s a risk worth taking
Well, after doing some research, I’m probably just going to get another Traxxas Lipo or depending on funding, I may just buy a much better charger for all batteries. I talked to some
people that said that even for a 5000 Mah 3S pack, I’m looking at closer to two hours for it to charge if it’s discharged and needing to be fully charged so I may just retire this charger. Only have thirty bucks for it several
years ago.
Old 10-07-2024, 11:18 AM
Broadwayme
So, do I get it right? You can't use this charger with other models?
Old 10-07-2024, 11:54 AM
Asminext
I’ve found it’s fine for smaller batteries, but when you go bigger, the charge times get pretty long, and the charger can struggle with the load.
Old 10-14-2024, 11:54 AM
Asminext
If you’re planning to stick with larger LiPos, investing in a charger built for those sizes might save you time and keep the batteries in better condition overall.
