EZ start wont work
Old 04-15-2005, 12:11 AM
bighitbiker3
Default EZ start wont work
Ok i have owned my Revo for a few months and it has seen a lot of use. But today my EZ start just stopped working. When i try to start the car the EZ start cycles a half turn and stops, its like there is a rock in it or something. So i went to take out all the screws to pull apart the EZ start to look inside but it wouldnt come apart. So whats the deal? Oh also the Motor light on the igniter isnt lit but the Glow Pug one is.
Please Help
Old 04-15-2005, 12:27 AM
jbuck
Default RE: EZ start wont work
Dumb question but did you check to see if the engine was flooded???
Old 04-15-2005, 12:48 AM
baddman
baddman's Avatar
will the motor spin by its self with your finger from the bottom of the car.... if not and is stuck ... check to see it the rod on the crank is broken.
[&o]
Old 04-15-2005, 01:50 AM
Will239
it could be th epinch of the sleeve? id try taking apart the engine... inspect for any damage or objects
Old 04-15-2005, 02:19 AM
BaSh_2_tHa_mAxX
BaSh_2_tHa_mAxX's Avatar
Check that your abttery if FULLY charged.
Clear your engine of any fuel.
Take out the plug and see if the e-z will turn it over. Then report back to us.
Old 04-15-2005, 05:03 PM
bighitbiker3
Ok this is what i have tried so far:
I checked to see if it was flooded, it wasnt
I tried turning the fly wheel but it wouldnt spin, it wasnt because of compression (it seemed jammed)
So what do i do?
Old 04-15-2005, 09:22 PM
rkutach
sounds like an engine problem... anyone agree???
Old 04-15-2005, 11:35 PM
bighitbiker3
Also my spur gear is catching when i roll the car backward. Also i tried spinning the fly wheel really hard and it moved for one rotation and then it got rock hard again...
Can i send it to Traxxas, if so will they replace anything free of charge. Are they really picky with warrenties?
Old 04-16-2005, 06:18 AM
baddman
baddman's Avatar
ORIGINAL: bighitbiker3
HERES WHAT HAPPENS
you need to find the prob first ....im sure if you pull off the crank cover you'll see the rod or something is not..... WELL ..... where it should be.lol
is so you can call traxxas and send it in and they should swap it unless they see like a SCREW FELL IN THE MOTOR or some thing that you have done.
but.. if it looks to them that you have ran it to hard they might give you a badd time..... but in the end will swap it out and say this is the last time we do this for you.
just my idea>>>>>>.anyways
