gear hessitates to accelerate
Old 09-19-2009, 05:48 AM
garyedwards
Default gear hessitates to accelerate
my car seems to accelerate for 3 seconds when i press the acceleration but then after 3 seconds it hesitates to go faster
Old 09-19-2009, 06:06 AM
bkfamily1
Default RE: gear hessitates to accelerate
what kind of vehicle?
Old 09-19-2009, 06:14 AM
garyedwards
HSP backwash 18cxp engine
Old 09-19-2009, 06:49 AM
ehroof
sounds like your running too lean, try to richen the needles a 1/2 turn each and see if that helps. (richen is turning counterclockwise.)
Old 09-19-2009, 03:03 PM
AllAboutFunHobbies
AllAboutFunHobbies's Avatar
1 + I agree sounds like a lean bog.
Old 09-19-2009, 05:14 PM
garyedwards
ok ill try that do i lean both needles out
Old 09-19-2009, 05:53 PM
Sgt.Jonny
No richen. Take your flathead screwdriver into one of needles first go LSN and turn it 1/4 a turn out so left or counterclockwise. Do the same for the gold needle (HSN). Let me know how it goes.
Old 09-20-2009, 04:44 PM
garyedwards
yes it working great now. But is this normal. Every halfadozen runs, my gear (no.06032 i think) wears out and the teeth are flattened is this normal if not what am i doing wrong
Old 09-20-2009, 05:24 PM
Swamp3r
Swamp3r's Avatar
Your mesh must be off, realign your motor. You should hardly go through gears if your mesh is right. If you need more help just ask.
Old 09-20-2009, 06:12 PM
Redharris
Redharris's Avatar
Gary......
I just finished helping another Himoto Family Member with the same problem YOU are having.
Check out this [link=http://www.rcuniverse.com/forum/fb.asp?m=9107935]POST[/link] to see what I advised HIM....
Old 09-21-2009, 12:09 AM
garyedwards
about that post, if u find a metal spur gear it recks ur diffs. I found a whole metal gearbox (single speed also comes with new clutch bell) from plaig. But my car is 2 speed but it say it replaces a 2 speed gearbox. What do u think about it. should i get it?
