I have the fuel go over the outside of the filter so when I clean it it makes easier to get the dirt off of it.
I also use plastic safe electronics cleaner that you can find at Home Depot.
Also use Biborg an anti algaecide in the fuel can.
Thanks for the input. Meaning that O ring should be facing Turbine which is logical being easier to clean. Is this how it is supposed to be? while in the manual it says O ring should face fuel pump?
Yes…. The O ring should face the turbine. The new filters also have a directional arrow showing the fuel flow routing. You should also try to mount the filter vertically.
Wayne
