200mm Bodie on a 190mm car???
wat will happen if i get a 200mm bodie on my 190mm car? becuase i want a SUPRA Body and there are like NONE for a 190mm car... what will a 200mm bodie look like on a car?
RE: 200mm Bodie on a 190mm car???
but i heard that some things liek the wheels will grind on the body... does anyone have pictures or know where i can see pictures of a 200mm on a190mm chasis
My Feedback: (158)
you're talking about putting a 10mm wider than normal body on a 190mm car
you will have 5mm each side extra space
it's when you put a 190mm body on a nitro 200mm car you start having issues
But like stated above it's only plactic, trim it to fit.
I once had a 190 porsche body on my rs4-3 nitro, it was tight but nothing rubbed
Picked up a 200mm body for drifting last week to fit the TC3 really looks good, Had to cut alittle on the back for the wheels , would suggest getting a Dremmel tool makes slicing and dicing easier, RED
I have 2 190mm electric touring cars. All I buy are 200mm bodies. They fit fine. You want to see what they look like mounted, check out my website:
http://studysession.com
Ya now thats what I'm talking about see how nice the 200mm bodies can look , I like running with mounting post a little shorter myself but other than that they look good, RED
you can also buy wide tires from hpi, i put a 200mm saleen body on my tc3 with wide hpi tires and rims, they turned the car into a 200mm cuz the rims an tires are 5mm wider on each side
Thanks for the compliments. The sad part is the WRX is the only one that I personally did not paint and that is the one everyone loves the most. I used that body on my Colt10 when I did my 93MPh run.
