Cutting Carbon fiber.. how do you do it?
CA,
you can guy carbon sheets from art's hobby. To cut it just use a carbide wheel on a dremel and cut carefully. Higher speed is generally better so you don't fray the fiber.
so you can make your own carbon fiber chassis with that stuff?
i dont plan on doing it just asking.
im too involved in this crazy aluminum project i got going on.
http://www.arts-hobby.com/store/item...pid=1&pcatid=0 thats the site for the carbon fiber
CA,
Yes, always do your carbon work in a well-ventilated area, and wear eye and respiratory protection. Yeah, you can make your own chassis out of the carbon, I'm in the process of building a custom chassis for a custom car right now. This thing should be cool...
Make sure that you have a really nice heatsink for that engine because the chassis helps aid in cooling, alot actually since there is so much airflow going under it. Also make sure its at least 3mm thick, and have some sort of upper deck that filts tightly onto it to keep it rigid.
i work in communications and we teminate fiber optics regularly so i know all about fiber saftey.
tell me more about this custom chassis. what kind of rig is it for?
CA,
Basically, I'm re-arranging an NTC3 for something other than touring.
