i need help with my 2 speed
Old 04-24-2003, 06:35 AM
r2drift2
Default i need help with my 2 speed
hello guys, i just got a two speed and it doesn't seem to work. i have adjusted it already many times and i still dont hear it working. so what am i doing wrong???? pls. help
Old 04-24-2003, 11:02 AM
Rex2342
Rex2342's Avatar
What kind of 2 speed is it and for what car?
Old 04-24-2003, 12:13 PM
droopy316
if its an hpi 2 speed use the other spring that came with it
Old 04-24-2003, 01:38 PM
GeorgeKelp
GeorgeKelp's Avatar
tell us what type it is, cause i was having trouble with mine and if its the same type of setup i can help you with it.
Old 04-25-2003, 05:10 AM
r2drift2
Default two speed
i have a hpi rs4 rtr3 and i replaced the old trani with a hpi two speed. i was fooling around with it again today, and it still wont switch. my engine is an o.s .12
Old 04-25-2003, 08:22 AM
r2drift2
Default just wondering...
so i have this 2 speed problem. i was just wondering. i had my o.s. engine for about 8 months now and its going to die real soon, its still running though, just not as fast as before. will that affect the two speed from not switching, or speed doesn't really matter???
Old 04-25-2003, 12:09 PM
Rex2342
Rex2342's Avatar
If the engine is not performing to its full potential the tranny won't shift.It has to reach higher RPM's to shift properly if you say the engine is going to die just rebuild it and then tune the tranny.
Old 04-25-2003, 01:39 PM
GeorgeKelp
GeorgeKelp's Avatar
first of all im confirming that you have part # 86038 from hpi, which is the two speed transmission. if so, then listen and i MIGHT have a solution. ok, once you slide every thing onto the drive shaft, there is the silver disk that has the two screws ( one of them is for the adjustment of the shift point.) that is supposed to go inside the thing in the second spur gear, once you slide that in, through the adjustment hole in the spur gear, put the allen wrench onto the screw that is NOT the adjustment one, and tighten that one ALL the way. make sure everything is snug and reasemble. that is what happened to my car once, for some reaosn that came loose and it wouldn't shift. if that does not work im sorry. but i tried.
Old 04-25-2003, 01:44 PM
GeorgeKelp
GeorgeKelp's Avatar
sorry, supposed to be called a "gear shaft" sorry about the wording.
Old 04-25-2003, 02:49 PM
Rex2342
Rex2342's Avatar
Make sure you tighten it on the FLAT side of the shaft if that is the problem and use a bit of thread lock on the set screw so it won't back out again.
Old 04-25-2003, 05:54 PM
dg2b
Check this thread and see pics. Hope it helps you out.
http://www.rcuniverse.com/showthread...ight=two+speed]
Old 04-25-2003, 11:23 PM
r2drift2
Default thanks guys
ok, i'll do my best, and i will let you guys know. thanks again, big time!
Old 05-25-2003, 08:32 AM
tkhoo
Hi Rex2342, may I know that how to know the engine already in HIGH RPM while running........My Yokomo GT4 also can't shift the 2 speed tranny. Need your help.............Thanks in advance.
khoo
