help setting the idle!
Old 05-24-2003, 10:46 PM
ianpog
Default help setting the idle!
hi! i've been having a hardtime setting the idle. if it idles high, i'd lower the idle but the engine stops!
is there some kind of leak?
any solution or comments?
Old 05-24-2003, 10:59 PM
packfan88
ofcourse we need more information to help you.
what car and engine is it and someone ca tell you the factory setting for that carb. you can look in the manual if you have it.
Old 05-25-2003, 06:59 AM
tkhoo
First u need to run you baby for few laps b 4 you do any adjustment.......b'cos you need to heat up the engine first. After that set you idle screw......somw like the engine can idle for 1 minute and some set it idle for few second....is depand on you.
