wide turns?
Old 05-25-2003, 08:37 PM
civictypenos
Default wide turns?
my car seems to take too wide of turns,i have a hitec 5625servo on my steering and a jp xr3 radio,any tips on getting it to turn more sharply?
Old 05-25-2003, 08:41 PM
gsferrari
Default wide turns?
Check your transmitter and see if you have reduced the action of the steering servo. Also check the steering linkage with the transmitter on so that there is no binding...
Give it a slight TOE-IN in the front and TOE-OUT in the rear.
Use softer front springs and thinner oil - stiffer/thicker in the rear.
You can also play with camber but I usually dont unless there is no other option...
