HELP PLEASE!
Old 01-10-2007, 02:38 AM
speeddy
Default HELP PLEASE!
ok i striped an allen key screw on the botton were it holds the engine mounts how do i get it out ?
Old 01-10-2007, 10:36 AM
running_gag
Default RE: HELP PLEASE!
Your could cut a slot in the screw head and use a screwdriver. or you could get an easy out.
Old 01-10-2007, 11:39 AM
krazor
as running gag said try the slot method
If that dont work got to a hardware store and get a screw extractor its like a drill but with a left hand flute on it you drill a pilot hole into the stripped screw and then turn the extractor into it its pretty simple
If that dont work [X(] youll need to carefully drill the whole thing out and retap it
Old 01-10-2007, 02:22 PM
shadow
like running_gag said try a drimel with a diamond blade cut it till it hits the chase then use a screwdriver.
Old 01-10-2007, 03:15 PM
running_gag
or a Plasma Cutter.
Old 01-10-2007, 05:48 PM
bte214
bte214's Avatar
If it is countersunk ca your allen driver into the screw, let it dry, twist it out. Or if you have one you don't care about you could solder it in instead.
Old 01-10-2007, 09:52 PM
speeddy
ty all
Old 01-10-2007, 10:10 PM
hands without shadows
hands without shadows's Avatar
ORIGINAL: bte214
I never thought of that, thats an awesome idea!!
Old 01-11-2007, 08:09 AM
running_gag
Abo****e worse case scenario, just buy a new one and send me the old one.
