need help with an OS engien and a RS4 3
NY
Hi. Ok so.. i just got the engine i changed the flywheel ect ect everything is fine except that
1. is like smaller dont reach the spur gears i will have to grind the holes?
2. i got the slide carb i need to change the servo backwards? ( the obvious )
sorry to ask but rather ask then do it like 10 times and maybe there was an easy way to it
oh and another question i notice the slide carb version the air filter hole is bigger any good air filters for it? i had a saver for my other engine but the hole is smaller dont fit
RE: need help with an OS engien and a RS4 3
Did you switch from a pull start engine to a non-pull start or vise versa? You might just need to switch your engine mounts.
Post some pics.
Post some pics.
NY
oh. no is a pull start thois the engine i got http://www2.towerhobbies.com/cgi-bin...&I=LXGGP6&P=ML
ill post pics in a few
