ORCA 6x esc with 10.5t New Burnt !!!
i have no idea.. it happen like this ..
here is my electric set up
* ORCA 6x Esc combo 10.5t
* tamaco servo
* sanwa m11
there is no more sound beep beep.
yes it will work for few min after that it can't work after i test my servo.. ( i turn quickly with my m11 left and right few times.. but previously i using yeah racing combo 35a 9T with no problem but only if i turn too fast the servo will jamming for around 1 sec but now the servo are perfect no jamming )
i have no idea what really cause my esc failed.. is that my servo cause it ? or setup ? or manufacture fault ?
pardon my poor english but hopefully you know what i trying to say..
tq
best regard's
* tamaco servo
* sanwa m11
tq
best regard's
RE: ORCA 6x esc with 10.5t New Burnt !!!
when i had my esc that went beep beep, it worked, shut down, then beeped a whole bunch, then afer a while i ran it again, it got stuck and then started on fire....
i was running WAAAAAY to hot a motor for that little esc, so im guessing that your esc is cooked.
make sure all your connections are good at the reciver, make sure all your batteries are charged (even transmitter) and try again. if all else fails and the esc doesn't wake up its dead.
also check without servo plugged in.
