Help with battery please!!!!!!!!
Old 09-08-2008, 08:12 PM
wicho001
Default Help with battery please!!!!!!!!
Hi guys!
I have 2 Brand new DTX 4200mAh NiMHs batteries and I use the Hobbico Accu-Cyle pro series Elite charger.
The thing is that I need a good set-up for this charger to use on this batteries
This is the current Set-up but its not working at all!
PEAK CHARGE
peak charge current 1.70A
Trickle current: 90mA
Peak sensitivity: 8mV/Cell
DISCHARGE 6.6V
Dischg current 0.30A
dsch cutt 1.1V/cell
CYCLING
Cycling charge 1.70A
Cycling Discharge 0.30A
Discharge cutt off 1.1V/cell
number of cycles: 1
Thanks alot guys!
Old 09-09-2008, 12:21 PM
guver
My Feedback: (325)
Default RE: Help with battery please!!!!!!!!
The set-up looks correct.
Capacity is set to 4200 and the mv can be set to 5 mv. Either way should charge the batts.
Old 09-09-2008, 01:12 PM
i8tweety
i8tweety's Avatar
I would adjust the peak charge current up between 4 and 5 amps. At 1.7 amp charge rate, it will take over 3 hours to charge one battery pack. Everything else looks good.
Old 09-09-2008, 01:32 PM
wicho001
thanks alot guys!
