center diff
center diff
with the new traxxas center diff for the revo will i gain any speed with it? i only drag race so i just want to know if i will get and more speed out of it.
AB, CANADA
RE: center diff
ORIGINAL: markcoznottz
can the centre diff be fitted to the short chassis 2.5r?. i have an rb323 and i dont wanna wheelie uncontrolably when i start her up
RE: center diff
NO you will not be able to use the 2.5 chassis with the center diff and rear brake. You will not gain more speed with the center diff, however it will give you more control while in the air. The Center diff allows you to "fish tail" the back wheels of truck on tight corners like a 2wd car. If you are just bashing around it is not necessary, but I tell you what it make your car a hell of alot funner to drive.
RE: center diff
ORIGINAL: tadecker
Why can't you use the 2.5 chassis. You just have to Dremel some chassis out behind the tranny for the rear brake to fit.
My Feedback: (29)
IA
RE: center diff
So to put the center diff in my old 2.5 I would need the diff kit, the brake kit, and a 3.3 transmission case, right?
Then do some dremeling to the chassis to get it together. Is there anything else? Has anyone done this to the 2.5 yet?
Ron
Ron
AB, CANADA
RE: center diff
You may need the rear center drive shaft to fit into the brake, similar to the front brake how that works. I am doing it as soon as the Canadian supplier gets mine to my LHS
About 2 more weeks [sm=thumbup.gif]
