removing foam tires
Old 02-16-2006, 11:28 PM
magz363
Default removing foam tires
is there any specific way on removing foam tires or is it just like removing rubber ones?bake them or boil them?
Old 02-16-2006, 11:37 PM
jakjr
My Feedback: (18)
jakjr's Avatar
Default RE: removing foam tires
As far as I know the foam is glued on with CA, just like rubbers, so the removal procedure should be the same. Bake, boil, acetone, etc.
As an alternative, if you have a lathe (a real one, not a comm lathe) or tire truer you could probably just cut the foam off, that would probably be the quickest.
Old 02-16-2006, 11:50 PM
magz363
thanx
