moves when idling
NY
moves when idling
I have to hold full brake on my SS for it to stay in one place while idling. I set up the slipper clutch according to the manual and checked the size of the opening in the carb. It still moves.
NJ
RE: moves when idling
lower the idle screw, so that it runs and doesnt stall out, adjust your linkages. Make sure the carb is closing all the way. I have also had this problem in the past. These helped cure it
