Battery Help
Battery Help
Could someone link me to a good nimh or nicd pack on A-Main for an SC10? I would be very helpful as I want to order one when i order my truck.
AB, CANADA
RE: Battery Help
Here are 3 side by side packs (superior to stick packs) nimh from amain.
http://www.amainhobbies.com/product_...wEC3-Connector
http://www.amainhobbies.com/product_...or-72V-5000mAh
Two are 6 cell 7.2v and the first is a 7 cell 8.4v. For all three you'll need to replace the connector with whatever your SC10 and charger has.
You can also look for EnerG packs at promatch.
RE: Battery Help
So how much better is the middle pack you posted than this?
http://www.amainhobbies.com/product_...ducts_id/25856
AB, CANADA
RE: Battery Help
That's a stick pack and won't perform as well as a side by side pack but it would be ok if you're looking for something cheaper. If you can afford it I'd go with a side by side pack but it's up to you.
RE: Battery Help
Nice! I just found that A-Main has a 25 off of 250 code so i might aswell go with the nice pack. Will it give better performance and run times?
