Seagull Models Super Star
My Feedback: (15)
Seagull Super Star 120
ARTF with
25CC Gas engine with Pitts Muffler and 17x8 APC prop.
HiTec HS7955 TG servos x 4 (two for ailerons and two for elevators)
Savox SC1232sg Servo for rudder
Two Futaba S3004 (one for throttle and one for choke)
Miracle double switch/charger with fuel dot.
Two Voltage regulators with low voltage warning buzzers.
RCexl ignition cutoff.
Has some hanger rash and will need some TLC to the covering plus Receiver, Batteries and a re plumbed of fuel system.
Manufacturers specs:
Wingspan: 69.3" Wing Area: 846 sq. in. Weight (as advertised): 10-11 lbs Weight (as reviewed): 10.55 lbs (4.785 kg) Length: 62.6" Wing Loading: 28.73 oz/sq. ft.
ARTF with
