Dreamworks New Products....
My Feedback: (24)
That time again... Here is a listing of our latest releases.
Pro-Link Shoulder Bolt - New Version - Large
Our New V2 Pro-Link Large replacement shoulder bolts are now standard on all of our large series struts; we have upgraded this bolt to a larger diameter for additional strength and an E-Clip groove for reliability.
We have had some reports of our Pro-Link shoulder bolts loosening up over time. While this bolt does require some periodic inspection, we have now added an E-Clip to retain the bolt even if it should loosen up. We still suggest periodic inspection of these bolts to ensure they are tight.
Robart "Liquid Sky" Smoke Oil
Available in 1 gallon, case of 1 gallon and 5 gallon containers
Boomerang Torus Pro-Link Gear Sets
The Pro-Link Torus package has been developed from the ground up specifically for the Boomerang Torus, featuring zero offset adjustable trailing link struts. Our new struts center the wheels in the well and include our new E-Clip shoulder bolts.
Offered as struts only or full combo packages.
Xdriver 4 Port DC Battery Charger/Discharger/Balancer
Tired of being limited to charging one battery at a time? Our new XDriver6 DC charger has 4 independent outputs, 4 LCD monitors. You can charge 4 Battery packs at the same time no matter what battery type you may have. This charger allows you to plug 4 batteries into one charger simultaneously, and it will intelligently and automatically charge all 4 of them at once to their maximum capacity. To top of it, the batteries being charged do not even need to have the same configuration. You can connect different chemistry(Ni-MH/Ni-CD/LiPo/LiFe/PB)batteries into any of the four charging ports. Each charging port provides an independent balance port for balance charging/discharging of the packs. We also include 2 ea (one each shown) of the JST and TP/FP balance plug adapter boards to cover every battery brand and style available. Also includes 5 Charge lead cables.
Specs:
* Operating Range: DC 11V-18V
* Charger Power: Max 240W (4x60W)
* Discharge Power: Max 20W (4x5W)
* Charge Current Range: .01~6.0A Per Port
* Discharge Current Range: .01~1.0A Per Port
* Cell Count: NiCd/NiMH 1~15 - LiPo/LiIon/LiFe 1~6 - Lead Acid 2V~20V
* Current Drain For Balancing: 300mA
* Dimension: 230x158x60mm
* Weight: 995g
Includes:
* 4 Port - 4 LCD Charger
* Plug-In Battery Clamps x 2
* TP/FP Balance Adapter x 2
* JST Balance Adapter x 2
* Tamiya Charge Lead
* JST/BEC Charge Lead
* Futaba/JR RX Charge Lead
* Alligator Charge Lead
* Bare Charge Lead
* Instruction Manual
Dual Output Power DC Power Supply 12V 20A
Our dual output 12V D/C power inverter can handle 20A per output port. Great for running any 12V electronics off 100-220V A/C such as field chargers.
Perfect match for our XDriver6 4 port field charger.
Dreamworks Dominator Logo Hat
* Comfy brushed cotton twill material holds its shape after repeated wear due to the cap’s mid-profile, structured design.
* Pre-curved visors shield your eyes from the sun’s rays
* Bold-colored six-panel hat features eye-catching, contrasting colored trim on the bill.
* Sewn eyelets and top button feature this same contrasting color.
* A tuckaway Velcro® closure at the back can be adjusted to the best fit.
* Size: One size fits most.
Kingtech K-170E
The K-170E is the second engine to be offered by KingTech. We are simply blown away over this new engine's quality and performance. The starts are smooth and throttle response is very respectable and all with very cool temperatures. Thrust specifications are well reserved, our bench test show the K-170E is providing thrust levels well over the 37lb spec even at 87F! The internal design is unique and original; quality cast components coupled with a heavy-duty J stick combustion chamber and a lifetime engine warranty are just the beginning. All KingTech turbines sold by Dreamworks will come complete less ECU battery and include time tested and proven fuel pumps and solenoids to provide superior performance and reliability. Also, in an effort to provide the best customer service possible, Dreamworks will be providing U.S. service for all KingTech turbines in-house.
K-170E Specifications-
* Diameter: 4.5 inches
* Weight: 3lb 10oz
Idle: 35,000 rpm
* Max: 125,000 rpm @ 37lbs Thrust
* Fuel consumption: 18.5 oz/min
* EGT: 650C
* Fuel: 5% turbine oil with Kerosene, Jet A1 or Diesel.
* Maintenance cycle: 25 hr
Skymaster / Xtreme Dragon Pro-Link Gear Sets
5 Function Multi Valve Pro - EVO
What can you possibly do to improve upon the amazing EV5U-PRO Multivalve you ask? Well, add landing lights of course! Working directly with Airpower, we have added even more functionality to the new EV5U-EVO Multi-Function valve system with the addition of a built in landing light module. Triggered by gear down actuation, all three super high intesity Luxeon emitter landing lights come on automatically. The EV5U-EVO offers everything you could possibly need or want in a gear system controller. We are proud to have the US Exclusive on this new valve. The newly revised software separates the sequencer timing so each setting is completely independent of each other, simplifying the sequencer programming. In addition, you can now test the antilock brake setting without having to exit the programming sequence. We have also added RX voltage readings directly off the LCD Display!
Features:
• LCD Display Screen
• Built In Gear/Door Sequencer
• Built In Gear, Door and Brake Valves
• Built-In Programmable Gear System Fail Safe
• Direct Onboard Programming
• Dual Digital Air Pressure Value Display for Brake and Gear
• Built in Landing Light controller with three light output
• Digital RX Voltage Display
• Accidental Gear-Up Failsafe Upon Power-Up
• Compatible with All 2.4 Ghz Radio Systems
• Intuitive and Simple Programming
• Three Pressure Unit Selection - PSI / Kg-cm2 / BAR
• Adjustable Brake Pulse Width and Anti-Lock Programmable setting
Specifications:
• Operating voltage : 4.8 to 7.2 Volts for DC
• Current Consumption : 650 mA - Max.
• Operating pressure range : 0~170psi / 0~11.7bar / 0~11.9kg/cm2
• Air Pressure accuracy : ± 2 %
• Temperature range : -10 to +75 °C
• Dimensions : L 69.40 x W 53x H 30 mm
• Weight : 4.94oz
Includes:
• EVSD-5U-PRO Smart Multi-function Valve * 1
• MTA-5U-PRO Mounting Plate * 1
• Barbed Tubing Connectors * 7
• Air Fill Valve Set * 2
• Airline Restrictors * 7
• T-Fitting * 2
• X-Fitting *4
• Clear and Concise Users Manual * 1
* High Intensity Luxeon Emitter Landing Lights *3
Modes of operation :
• Mode-1
Gear doors open up, Undercarriage out, Gear doors stay open.
Undercarriage in, Gear doors close.
• Mode-2
Gear doors open up, Undercarriage out, doors close.
Gear doors open up, Undercarriage in, doors close.
• Mode-3
Gear doors open up, Undercarriage out, 2 doors close, 1 door stays open.
2 doors open up, Undercarriage in, 3 doors close. (Requires one additional Dual Action valve)
• Mode-4 Customize
User can program sequencing of each of the five valves independently offering unlimited options.
• Mode-5 Manual
No RC Controller required, valve can be operated through the programmed sequence by simply pressing the button on valve face.
Smart-Smoker Pump, Adjustable Flow/Smart Prime
Key Features
* Smart Prime technology provides the power to prime itself
* Intelligent Flow Rate Controller fine-tunes oil rate for optimum performance
Overview
The SmartSmoker ™ is based on its predecessor, “The Simple Smoke Pump II" which is an easy to install smoke system that doesn’t require pressure tapping or complex plumbing, valves and servos. For the SmartSmoker ™, TME has designed a new intelligent Flow Rate Controller. Now you can fine tune the oil rate of your smoke system for optimum performance from the transmitter! Plus, the advanced microprocessor controller also features "Smart Prime ™" technology that provided the power to make the initial prime effortless.
Adjust for optimum smoke from the ground:
The new pump controller in the SmartSmoker â„¢ eliminates the restrictive pinch valve, saving precious battery power and adding the convenience of fine tuning the oil rate from the transmitter. The special Flow Rate Controller is not just a standard motor speed controller. This design provides a full adjustment of the flow rate by setting the transmitters end point adjustment. (Sometimes known as ATV or EPA)
Smart Prime â„¢ Technology provides the power to self prime:
The Smart Prime ™ technology is a TME first and works like this: The first time the SmartSmoker ™ is powered up, the controller defaults to its Smart Prime ™ mode. In this mode the first time the pump is activated via the transmitter, it turns on like a switch running the pump at full speed. This assures you have the power to pull up the oil and initialize the prime. As soon as the oil flows through the pump, simply shut off the pump at the transmitter. Now the next time you turn on the pump, it runs at the pre-programmed flow rate defined by the transmitter’s end point adjustment. Smart Prime ™ technology is a simple but effective way of assuring prime.
AirPower Air Cylinder - 6" Stroke
These new light weight aluminum cylinders from AirPower are perfect for air brake and canopy actuation.
Specs:
* Length : 205 mm
* Stroke : 6" - 150mm
* Dia : 12mm
* Weight : 15 g
* Function : Air extension / Air Return
* Suitable : All Turbine & EDF Jet ..etc.
This unit specifically fits the Skymaster 1/5 Scale F-86 for Canopy Actuation.
As usual... Lots more new items listed in our "Whats New" section, More exciting products on the way!! We have a new category... "CLEARANCE" where you can find substantial savings on some discontinued, over stock or open box items.
Specs:
* Weight: 995g
Includes:
* Bare Charge Lead
Kingtech K-170E
* Weight: 3lb 10oz
Idle: 35,000 rpm
* EGT: 650C
Features:
Specifications:
• Weight : 4.94oz
Includes:
• T-Fitting * 2
• X-Fitting *4
• Mode-1
• Mode-2
• Mode-3
• Mode-4 Customize
• Mode-5 Manual
Key Features
Overview
Specs:
* Length : 205 mm
* Dia : 12mm
* Weight : 15 g
