Carbon fiber wing tube messy?
I just got my cf landing gear and wing tube from graphtech. They do feel much lighter than my stock stuff. The wing tube is very messy though. I get a fine powder on my hands when I hold the tube and I noticed it leaves a residue in the tube on the fuse. Is this normal????
My landing gear is fine. It has a smooth surface and is what I'm used too with carbon fiber. I'm worried over time the tube will wear down and have play in the tube inside the wings.
RE: Carbon fiber wing tube messy?
The dust on the tube is normal. Also leaving carbon on your hand is normal. C/F tubes are pretty tough. I wouldn't be using one for a baseball bat, but they will take a larger load without bending than the aluminum tube you had, at a much lighter weight. You also gain the advantage of cutting the tube to the exact length of the wing sockets to eliminate any end to end movement of the tube, should you choose to do so.
To stop the residue from getting all over your hands and whatever, use a decent quality automotive paste wax and wax the tube. This seals the surface, preventing the transfer of carbon to your hands, with a side benefit of letting the tube slide easier into the wing and fuselage.
PA
Hi - I suspect the tube is rotating in the phenolic and wings while in flight. Another thing you can do is use an automotive hose clamp around the phenolic in the fuse. This will keep the tube from rotating and stop the cf tube from wearing.
jon
reason for edit - added pic
jon
I just put my cf wing tube and landing gear on an accurate letter scale and I saved almost a whole pound of weight!!! Almost 7oz of savings just from the wing tube alone!!! I bought the wing tube from graphtech for 44.00. 7.4oz savings from the gear. This is for a Hanger 9 extra 330s(new version)
PA
ORIGINAL: Turbobruce
Thanks guys,
I havent flown the plane yet and I wasn't sure about the surface. I feel better now.
Thanks guys,
ORIGINAL: Geistware
INteresting, I was thinking about that for a new project of mine. A pound sounds like a lot
I would not have believed it myself if I did not see it. You can really feel the difference just by holding the gear and tube in your hands. Once again, the scale I used is my buddies and he weighs his falcons with it and it has to be on the money. I was really surprized at the savings from the wing tube.
My Feedback: (25)
AR
I KNOW mine wasn't rotating in flight... man that thing was tight (it still is, but I sold the plane). The Troy Built tubes are just a little on the messy side... I will try the wax if I get another.
Geistware,
I did some weight comparisons for the gear and wing tubes with a 28% Wild Hare plane at the post office. I figured that the scale our governments have us pay for should be reasonably accurate, since out government will never spare us any expense in the quest for the best possible equipment.
Anyway, using the Troy Built suplied c/f wing tube and Graphtech c/f landing gear, there was close to 15 ounces reduced from the planes weight from when it was equipped with aluminum components. I ended up using fiberglass landing gear in the end and re-gained 6/10 of an ounce over the c/f gear, but the glass gear was quite a bit stronger.
The C/F wing tubes are a lot stronger than the aluminum tubes, and arrive at your door as straight as they can be. Sometimes I think the aluminum tubes arrive pre-bent, and only get worse with time and flight stresses.
Is the carbon stuff worth the money? That's something that each has to decide upon.
Pat
Pat
