Slinging grease
SC
Slinging grease
My cable is slinging grease all over my transom, is this normal? I am using a bearing grease on my shaft and my stuffing tube is even with the back of the transom. This is more of an annoyance than anything, but would be nice to come home and not have this mess. By the way the best way I have found to clean the grease off is with WD-40 and a rag.
RE: Slinging grease
if you leave a bit of tube out the back of the boat then put a bit of ruber hose on it 1/2 on tube and 1/2 on cable helps stop that and keeps the water out
RE: Slinging grease
It is normal but there are greases that won't do that. Grimracer cable grease and Speed Lube won't and I would assume some others also. You might want to go a little lighter when lubing the cable and wipe off any excess around the drive dog. Too much grease can be as bad as too little.
Banned
RE: Slinging grease
ORIGINAL: Ron Olson
RE: Slinging grease
Bearings, and more accurately load bearing surfaces need to "float" on the layer of lubricant, be that oil or grease. Overpacking stops the supported shaft from being able to move up and onto the wedge of lubricant that it runs on, hence causing additional drag and heat, so yes, it is possible to over lubricate.
Ron is correct.
Plus, of course, the extra stuff you spray all over the place ends up on your boat and possibly in the very water you are running on. Not good. And wasteful too.
Glenn
Ron is correct.
Glenn
RE: Slinging grease
I use a high temp type grease . It holds together really well and pretty much stays put in the stuffing tub on the flex shaft where it needs to be . I only put a thin coat on the flex shaft when I install it in the stuffing tube . At the end of the day there is still grease on the shaft like it needs to be . I don't get any slinging or leaking out of thestuffing tub . And yes to much grease can be a bad thing . I also get longer life out of my flex shafts since I have started using a high temp grease .
RE: Slinging grease
ORIGINAL: glennb2006
Ron is correct.
Glenn
Ron is correct.
Glenn
I've never heard of anyone complain that they had too much grease on their flex shafts
Banned
RE: Slinging grease
ORIGINAL: DowntownNC
If there's too much grease in it, I guarantee the shaft will spit it out within the first lap around the course...if it was an enclosed isolated area where grease could not escape, I would easily agree with what's being said. But it's not...grease can easily escape in a very short amount of time, if it's too much.
Ron is correct.
Glenn
Ron is correct.
Glenn
LOL! Not to mention, you can only use as much grease as the stuffing tube will allow to push through while on the shaft. But what do i know... ive never broke a flexshaft from lack of grease
