reverse
reverse
when you buy the reverse module (not savage x), do you need to buy a servo to operate it? and if so which one? oh, and does anybody have reverse? is it useful?
NY
RE: reverse
Yes you need a seperate servo and a three channel radio. Just get a cheap servo, you don't need anything fast or powerful. As far as useful, would you rather walk a hundred feet the get your truck out of a jam or just stand there and flip a switch?
RE: reverse
ORIGINAL: Dave33
RE: reverse
ORIGINAL: IBrakeForNobody
Yes, but also, would you want the additional gears in the reverse module slowing your truck down? After all, when the engine gets going in forward, it also has to spin the reverse gears as well as the forward gears, along with the additional weight of the shifting servo.
would that even make a noticable difference in performance?
NY
RE: reverse
[/quote]
What? The only time the gears in the reverse module spin is when it's in reverse. The reverse module does not take away any power from the engine.
[/quote]
RE: reverse
Just goes to show, never assume anything. Most of the other monster trucks I've seen spin the reverse gears as well as the forward gears when the truck is going forward.
RE: reverse
The reverse module has a gear that engages when in reverse, or is disengaged when driving fwd. When disengaged the gear spins freely of the other gears creating very little drag. It's only when this gear is engaged that it's operating the idler gear and the main gears. Have a look at the exploded view of the reverse module on the HPI USA site if still unsure
