Edge 540 CG & throws?
My Feedback: (20)
A buddy of mine gave me a Wild Hare Edge 540 that had been damaged.In the process
of repairing it.Had to rebuild upper half of rudder,upper half of the fin,hole in left side of fuse,
holes in bottom of stabs and couple small holes in wings.
Not sure if it isV1 or V2.how do I tell the difference between the two?
Is the CG the same on both?and where?wingtube?What is a starting amount of throw
for the control surfaces on low andhigh rates?What is the servo torque rating for the control
surfaces?Aileron/Elevator/Rudder?
Thanks Roy
Thanks Roy
RE: Edge 540 CG & throws?
V1 has sheeted foam wings, v2 has built up wings.
CG on the wing tube, use throws from any of the manuals on our web site for aerobatic planes, like Extra. They are all the same.
