~NEW~ OVERDOSE Drift Accessories
New OVERDOSE Drift Accessories now at Banzai Hobby!!!
Looking for my Bling for your Drift then look no more the New OVERDOSE drift accessories are here an many colors to match your Drifter!!!
Aluminum Bumper Support & Body Post Set for Yokomo and Divall Chassis
Aluminum Servo Saver Horn
Get in quick as Stock is limited and will sell FAST!!!!
Please check us out on Facebook for Weekly Updates and Specials
Banzai Hobby Tea
Banzai Hobby Tea
New From OVERDOSE the Aluminum Front and Rear Shock Tower For the Yokomo Drift Package are now at Banzai Hobby!!!
Aluminum Front Shock Tower For the Yokomo Drift Package
Aluminum Rear Shock Tower For the Yokomo Drift Package
Please Check us out on Facebook for weekly Specials and Updates!!!
Banzai Hobby Team
Banzai Hobby Team
The NEW Silver Carbon Chassis Set for DIB is now at Banzai Hobby
DIB Silver carbon chassis set Main: 2.4mm, Upper: 2.0mm. The adoption of the manufacturer and is jointly developed with newborn Silver carbon material is the emergence of the above quality until now. Thickness has secured chassis stiffness excellent balance between grip and controllability by the main chassis 2.4mm, upper chassis 2.0mm. Design, adopt a tribal design is the true value of OD. Put in the hands of real coolness that in other can not imitate.
OVERDOSE DIB Silver Carbon Chassis Set
Get in quick as these are selling FAST !!!
Banzai Hobby Team
Banzai Hobby Team
New Drift Accessories OVERDOSE
Aluminium Main Chassis for Vacula & Divall
Using 3mm 7075S Duralumin Chassis for rigidity. Perfect for high grip course or high speed course, enhance control-ability.
Further more, 90g heavier than standard Divall Normal Chabon Chassis, this will enhance lower gravity.
Aluminium Front Suspension Arm for Divall / Vacula RED
Using Step Adjust System. You can easily adjust / extend up to 4mm (0.5mm pitch) per side easily and quickly.
Further more, using with Overdose Adjustable Upright, you can adjust king pin angle and tread.
Aluminium Front Suspension Arm for Divall / Vacula Black
Please join us at Facebook for weekly specials and updates
Banzai Hobby Team
Banzai Hobby Team
New OVERDOSE WORK EMOTION CR Kiwami 3mm Offset now at Banzai Hobby!!!
Comes in 3 Colors
White
High Chrome
Matte Chrome
Get in Quick before they sell out!!
Please join us at Facebook for Weekly updates and Specials!!!
Banzai Hobby Team
Comes in 3 Colors
White
High Chrome
Matte Chrome
Banzai Hobby Team
New From OVERDOSE
WORK VS KF Matte/High Chrome Offset 3mm
Aluminum Antenna Post Type-3
Machined PTFE shock piston set (for OD high grade shock / ∅ 0.5x2, ∅ 0.5x3, ∅ 0.5x4, blank)
Please Join us on Facebook for Weekly Specials and Updates!
Banzai Hobby Team
Banzai Hobby Team
New from OVERDOSE !!!
Center Universal Joint for Divall (RED)
Center Universal Joint for Divall (PURPLE)
Get in quick while stocks lasts!!!
Banzai Hobby Team
Banzai Hobby Team
New OVERDOSE Divall Bevel Gear Sets at Banzai Hobby
Bevel Gear Set (35T / 20T)
Bevel Gear Set (42T / 14T)
