Savox Servo's Suck
Savox Servo's Suck
My futaba striped the only plastic gear in it this weekend while racing with other 1/8 scale buggies. It was about 5 months old anyway so I replaced it with a Savox sc-0251mg servo. The Savox was installed to my rc8.2e, I turned left, then right and pop! This is what happened. It broke in 10 seconds.
Well at least Savox offers spare parts to fix the servos. I got the case for $7 and repaired it. It was mounted with rubber spacers in between the tab and the chassis this time so it's holding up so far. Rants over, lol.
ouch that sucks... ive only ever seen that once before....
if its pumping out 13.0kg-cm/180.5oz-in and the EPA wasn't set.... no wonder it broke.
hey, at least u know its that powerful it can rip its own mounts off
might be worth just double checking the servo saver.... I would of thought that it would of prevented this from happening?
Moderator
I think it might be operator error.......
With that damage, I'd make a post about how awesome Savox servos are. Only an amazing servo has the immense power to break its own casing.
Exactly. I hate to say it, but Savox servos do suck, not for the reason the op mentioned, I expect that was an accidental weakness from the plastic manufacturing process, it happens. The reason they suck is the power draw. They drain receiver packs like nothing, and electric cars require separate BECs to avoid browning out of the ESC, which is just a PITA.
I've been reading that.... Im keen to know more... is across the board with savox servos? Are they all like that?
generally speaking is there a better servo for the same price or cheaper? Some of the other brands can get very expensive... Just saying
As for being something better for the price...that's a matter of opinion. Essentially, spec wise, no there isn't under most circumstances, but if you're willing to go up to around the 100 buck mark, there are some much better servos. They cleverly filled a price niche with the right specs.
I believe that all of them pull more than they should, but its the high power ones that make ridiculous demands of the electronics, particularly the very high speed and torque ones. I had these problems with the 1256 and 1258 servos, they made all my castle ESCs go nuts until a BEC was installed, but I can't speak personally for the others.
I think Savox are great for their money. With how good lipos are for rx packs or in electrics that have a good enough esc (Not that castles aren't good enough, but their internal BEC's stink) I think Savox are some of the best servos you can buy.
