Quadra 35 disassembly
SC
How do you get the prop hub and flywheel off an old Q35? It looks like the hub must be a press fit, but want to be sure before I start. The plastic points cover is loose and the flywheel is no longer running true after a "landing incident"
My Feedback: (49)
AZ
RE: Quadra 35 disassembly
Like TKG said,unscrew hub 2-3 turns,hold flywheel with hand and tap end of hub with hammer until flywheel breaks or comes loose from crank.DO not take the hub off and hit the threads of the crank with a hammer or any other tool.
SC
Thanx guys. Got the flywheel off. Obvious bent crankshaft. Any ideas on repair? This is an OLD engine, but with low time. Winter is upon us soon and projects are lining up.
