Free clamps
Old 09-14-2009, 10:32 AM
Walther
Default Free clamps
I am not sure if this has been on here or not but this is my free clamp.
Old 09-14-2009, 10:36 AM
Walt Thyng
My Feedback: (9)
Default RE: Free clamps
Cool! Never seen this tip before, but I'll have a batch of them by nighfall.
Thx,
Walt
Old 09-14-2009, 02:42 PM
grubbyjeans
grubbyjeans's Avatar
ORIGINAL: Walther
Only thing wrong with that is my name isn't on it!
grubby
Old 09-14-2009, 04:24 PM
KitBuilder
KitBuilder's Avatar
So i guess varying the width will provide different pressures? I'm wondering how to make protectors for the ends. ahaa.. you could use the same pvc and put rounded bottoms held on with the pvc glue... You would need to reduce the clamp space the width of the protectors...
Here is a pic but this may be overkill of a very good idea??
Old 09-14-2009, 04:34 PM
Walther
Yes; the size will make the pressure different, as in smaller or more thin. What we need is someone to come up with a tool that would let you expand them with one hand.
Old 09-14-2009, 06:43 PM
Villa
Villa's Avatar
I have been using the wooden spring loaded clothing line clips for years as clamps for building R/C models. The clips can even be taken apart and reassembled "backward" to better serve our requirements.
Old 09-14-2009, 08:58 PM
Lnewqban
Lnewqban's Avatar
ORIGINAL: KitBuilder
An idea as simple as great, just improving a very good one!!!
Old 09-15-2009, 05:20 AM
Luftwaffe Oberst
Banned
Nice!!!!! Great Idea!!!
Pete
Old 09-16-2009, 09:24 AM
Walt Thyng
My Feedback: (9)
Shared your tip with Fox Valley Aero club and got a good idea back: use slit fuel tubing on the cuts to avoid marking the surface.
WT
Old 09-16-2009, 10:19 AM
Walther
Thank Walt! We still need a wood plier to spread them.
Old 09-18-2009, 08:41 AM
KitBuilder
KitBuilder's Avatar
ORIGINAL: Walt Thyng
WT
right.. much better !
Old 09-18-2009, 08:43 AM
KitBuilder
KitBuilder's Avatar
I experimented and could spread them with the backs of my index and thumb fingers "inside" the "C".. leaving my other hand to postion pieces, etc
Old 09-18-2009, 10:29 AM
Walther
KitBuilder; some of us getting weak and a pliers would come in handy.
Old 09-18-2009, 02:44 PM
Walt Thyng
My Feedback: (9)
I haven't tried this yet because it just occurred to me while checking this thread, but why couldn't you make a tool using a clothes pin? Run a screw or bolt through both sides of the jaws (inside to outside). Then squeeze. If you left a point on them they would act as holders as well. You might need a couple or three different sizes.
I'll make one up this evening and see if it works.
Walt
