CARF Joker build thread
Old 09-20-2017, 02:54 AM
Dave Wilshere
Default CARF Joker build thread + video
I collected two Joker kits at JP and although I don't really have time to build one atm I've started one a friend is having, doing the jobs he will make a mess of :-)
The canopy glass fit is easy, what you see here is the process and dry-No glue yet, fit in the frame.
The model has some nice detail, tank mount done for the round tank, removable radio/servo plate. Access is good.
Quality is great on this kit, amazing value
ID:	2232805   Click image for larger version
ID:	2232806   Click image for larger version
ID:	2232807   Click image for larger version
ID:	2232808   Click image for larger version
ID:	2232809   Click image for larger version
ID:	2232810   Click image for larger version
ID:	2232811   Click image for larger version
ID:	2232813   Click image for larger version
ID:	2232814   Click image for larger version
ID:	2232815   Click image for larger version
Old 09-20-2017, 04:19 AM
Dave Wilshere
OK, I've built the tank too, so Mark is hopefully good to finish the rest, I have also test fitted the MacGregor 2607 servo we will use. 7kg 26g, metal geared, they are a perfect fit.
Tank. Dubro soldered barbs, M&R Hi Flow felt clunk, tygon tube clunk line. I put a few hundred ml of meths in the tank to flush out any dust. The felt clunk is assembled and a clean syringe is attached and rapidly drawn out to suck any loose debris inside the clunk from assembly. The tygon is retained at each end by a ring of tygon tube to clamp it down. The overflow pipe is extended with another piece of tygon, the top cut in a V so it can't seal on the top wall. Tubes on the tank bung are blasted clean inside with a shot of CA kicker (aerosol type)
Lastly the tank is pressurised with my mouth and sealed with a loop of tygon. This will be left overnight and the pipe pulled off to check there was still pressure. Done!
ID:	2232817   Click image for larger version
ID:	2232818   Click image for larger version
ID:	2232819   Click image for larger version
ID:	2232820   Click image for larger version
ID:	2232821   Click image for larger version
ID:	2232822   Click image for larger version
ID:	2232823   Click image for larger version
ID:	2232825   Click image for larger version
ID:	2232826   Click image for larger version
ID:	2232827   Click image for larger version
ID:	2232828   Click image for larger version
Old 09-20-2017, 07:49 AM
skymaster68
Great dave, mine arrived yesterday... what size turbine are you using?
Old 09-20-2017, 07:55 AM
Bob_B
Bob_B's Avatar
Looks good, but when does the EDF build thread begin?
Old 09-20-2017, 08:07 AM
Dave Wilshere
SM68. This one is for a customer, he will either use a P-60 or P-100Rx.
Bob...when everything else is done! Mephisto build needs finishing and I have a SM A-10 to build for a customer!!
Dave
Old 09-20-2017, 09:35 AM
Bob_B
Bob_B's Avatar
Well you best get busy and off the net!
Old 09-20-2017, 02:39 PM
wfield0455
My Feedback: (7)
wfield0455's Avatar
Dave
Is there enough room you could fit an older P80 in there ?
Old 09-20-2017, 09:07 PM
Dave Wilshere
No, old P-70 is the largest turbine that would fit. It was designed to stop people putting 120-140 turbines in it.
Old 09-21-2017, 04:12 AM
tassos p
tassos p's Avatar
What's the capacity of the fuel tank please?
Thanks, Tassos
Old 09-21-2017, 04:47 AM
Dave Wilshere
Just over 2ltrs.
Old 09-21-2017, 07:56 AM
ZB
Is there intake ducting or just holes up front?
Zb
Old 09-21-2017, 07:59 AM
Bob_B
Bob_B's Avatar
Zb
Just the opening, but it would be easy to create ducting on a 3D printer to bring air back to the fan.
Old 09-21-2017, 08:38 AM
scaryxxl
hi there guys!
here is my joker fresh from Jetpower.
Name:	IMG-20170919-WA0010 (Copiar).jpeg
ID:	2233000   Click image for larger version
Name:	IMG-20170919-WA0012 (Copiar).jpeg
ID:	2233001   Click image for larger version
Name:	IMG-20170919-WA0014 (Copiar).jpeg
ID:	2233002   Click image for larger version
Name:	IMG-20170919-WA0016 (Copiar).jpeg
ID:	2233003   Click image for larger version
Name:	IMG-20170919-WA0023 (Copiar).jpeg
ID:	2233004   Click image for larger version
Name:	IMG-20170919-WA0025 (Copiar).jpeg
ID:	2233005   Click image for larger version
Name:	IMG-20170919-WA0027 (Copiar).jpeg
Old 09-22-2017, 02:49 AM
Dave Wilshere
I've already been asked these questions :-)
Balance I'd put at 180mm back with a small amount of fuel in the main tank Gear down.
Elevator 15mm up 16mm down. Ailerons 14mm up and 16mm down (expo on both 30%) Rudder max you can get which is 30-35mm I think.
Flaps 20mm take-off and as much as you can get landing. Down elevator needed 1mm take off and 3-4mm on landing.
Manual is coming
Old 09-22-2017, 03:03 AM
Bob_B
Bob_B's Avatar
Scary is the green as vibrant and dark as your photos show online? If so I really like the looks of that color.
Old 09-22-2017, 03:06 AM
scaryxxl
hi Bob
the green is the same one that appears in official site of carf, my photos are little dark because of light.
but is the real batman's joker clour
Old 09-22-2017, 03:07 AM
scaryxxl
Manual is coming
Hi Dave this info is the official from carf? or your own setup?
Old 09-22-2017, 05:05 AM
skymaster68
Old 09-22-2017, 05:23 AM
Dave Wilshere
Set up is my experience with this aeroplane.
Yes, the gear would normally be installed, but these first 7 kits the gear did not arrive in time before the container left...plus I would take out to check screws and coat wood in resin...so I'm glad!
Old 09-22-2017, 06:15 AM
erh7771
My Feedback: (30)
Do you mind weighing the bare airframe?
Looks like a JF 100 will fit in there easy
Old 09-22-2017, 06:21 AM
Bob_B
Bob_B's Avatar
It will fly on the JF but I would not have the performance I would be happy with. This is a large model
Old 09-22-2017, 06:55 AM
erh7771
My Feedback: (30)
Nice thing about Carf sport models is they don't need a lot of thrust energy to go fast, here's the larger model Carf flash that can fly close to 180 mph top speed with only 16 lbs of thrust installed from EDF ... starts around 4:50
JF 100 on 5000 14s is over 16lbs of thrust installed and efflux in the 240 mph with 780kv HET and this is a smaller plane
Great candidate for EDF for me
Old 09-22-2017, 07:01 AM
Bob_B
Bob_B's Avatar
Not sure where you get the idea that the flash in the video was doing 180? Trust me on this, it flew very nice, but more in the 130-140 range which was quite fast!
I am the CD of this meet and had first hand experience watching it fly, with interest.
Old 09-22-2017, 07:54 AM
erh7771
My Feedback: (30)
I read it on a translated forum but can't source the link, I'll defer to your first hand account of the speed but I was happy with it and would be cool to see similar installed static thrust and efflux in the smaller Joker with a JF 100 or 110
Old 09-22-2017, 07:55 AM
scaryxxl
Dave if you have the joker ready to fly can you post some pics inside the model to check all and see more photos?
