K210 Diesel settings in cold
My Feedback: (34)
Ok I normally don't like to buy used but with Christmas here it was all I could afford.
I got a nice k210. I pulled up the manual manual and updated the diesels settings, I know it's cold out side so lowered starting rpm to 3k due to it being 35deg out side as per the manual
I'm using a 3 cell life
I'm never getting a pop, I have everything on a bench to make sure it's not a install error
What setting are you guys using for a k210?
Thanks mike
Thanks mike
My Feedback: (9)
Thanks mike
Thanks mike
What setting is the ignition fuel at now?
My Feedback: (9)
NO 35 IS WAY TO HIGH! it should never be that high. You will flood the engine and cause a fire. Are you sure your pump is pumping fuel?
Call me Barry and Dirk. I could see moving it up to lets say 20 or even 22 but not 35. That would push so much fuel in it flood the ignitor out.
