2300 dead...
2300 dead...
I went to spark up my jet today and nothing. No led's on the switch plate, dead. There's power to the ECU and the switch is operating properly. Any idea why a Simjet 2300 would just stop working? There's no fuse in the ECU lol, so forget the obvious. It was fine when I put it away for the season last year. Anyone?<div id="myEventWatcherDiv" style="display:none;"></div>
RE: 2300 dead...
Hi
I have the same problem with my first Simjet, and it's has the old ECU in a green crimp plastic house. I never understand what was wrong with it. It was just dead one day.
So I strongly recommend you to buy a newer ECU. Gaspars ECU work perfect with SimJet. If you need the settings for it, just let me know.
Jonas
Jonas
RE: 2300 dead...
Where would be the best place in North Ameriica to purchase a Gaspar ECU? Thanks!<div id="myEventWatcherDiv" style="display:none;"></div>
My Feedback: (29)
ON, CANADA
RE: 2300 dead...
I just put a Xicoy V10 ecu on a Simjet 2300. Works like a charm.....
I ordered direct for Xicoy..Fast delivery, excellent service...
He has guidelines on his page for what you want to do.
http://www.xicoy.com/upgrade.htm
RE: 2300 dead...
So from what I read on the web site, the thermocoupler, gas valves and motor need to be changed as well? Think I'll bite the bullet and go with the V10. Would you share you parameters? Thanks!
ORIGINAL: Gary Arthur
RE: 2300 dead...
OK, I ordered the V10 ECU with new valves, rpm sensor and thermocoupler. So do you think I need the 6v speed 400 motor, or will the old one work? Anyone want to share their parameter for the 2300? Thanks! I also ordered the Gyrobot 900 jet, so it will be exciting to see how the old DV8R handles with some new upgrades.
My Feedback: (29)
ON, CANADA
RE: 2300 dead...
ORIGINAL: shaunrbell
<div id=''myEventWatcherDiv'' style=''display:none;''> </div>
My Feedback: (13)
Here are my 2300 parameters using a AU-605 Xicoy ECU
Start menu:
Pump Start Point AUTO +2
Pump Start Ramp 006
Glowplug Power 1.8V (using 2 cell lipo)
Gas Start Adjust 59%
Low Batt Volts 7.2V
Starter ignition power 070
Starter ignition max rpm 5,000
Starter ignition min rpm 2,000
Pre-heat time 2.0 seconds (I think this one can be reduced)
Gas off RPM 13,000
Starter power at fuel ramp 065
RPM 100% starter power 23,000
RPM off starter 21,000
RPM reconnect 19,000
Start mode auto-gas
Run menu:
Full Power Speed 122,000
Idle Speed 30,000rpm
Stop Speed 20,000rpm
Start/min temp 100°C
Max Temperature 800°C
Acceleration delay 004
Deceleration delay 011
Stability delay 090
Pump Limit 1020
Start menu:
Pump Start Ramp 006
Low Batt Volts 7.2V
Gas off RPM 13,000
Start mode auto-gas
Run menu:
Stability delay 090
Pump Limit 1020
NJ
Hi Edgar
Thanks for the info.
Simjet never had a Kerostart.
you have to change the thermocouple if using the Gaspar Ecu.
you can use the starter and pump but have to change the connectors.
