Help identifying this car
SD
RE: Help identifying this car
Just to give you a heads up.
The new style 12th scale rear wheels are now a 3 bolt where the old style were a 2 bolt. That will require new hubs that will accept the new wheels.
ORIGINAL: OvalRacer99
When I was looking, I was going mad.... I ordered a new left hub and some tires from stormer hobbies today. I am assuming the right will be ok since it is a slip diff that holds the right on.
SD
No it will not work, the old style has the diff bearing in the wheel and these new style the bearing is in the hub.
[img]file:///C:/Users/JENAND~1/AppData/Local/Temp/moz-screenshot.png[/img]
The left hub and the new tires came in today. Will try it out and see how well it does or does not work.....
Worse case scenario is I have to also buy the right hub.... Hopefully will have new pictures to post if I get it to fit.
[img][/img]
[img][/img]
Do you have a link where I can get one of these? I can't find it on EBay or stormer hobbies....
SD
ORIGINAL: studysession
[img][/img]
[img][/img]
http://www.teamirsrc.com/
https://www.ssl-stormerhobbies.com/c...mp;pn=ASC4553B
https://www.ssl-stormerhobbies.com/c...amp;pn=ASC4566
https://www.ssl-stormerhobbies.com/c...amp;pn=ASC4608
