Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Battery Discharge Rating?
Old 11-21-2008, 09:19 PM
fishingkittyman
Default Battery Discharge Rating?
Can someone tell me how I can tell the discharge rating on a battery if the sticker on it says that the Max c discharge is 49.5 amps. It is a 11.1v 3s 3300 Mah MaxAmps battery, any help would be appreciated.
Old 11-21-2008, 11:38 PM
jdetray
jdetray's Avatar
Default RE: Battery Discharge Rating?
The phrase "Max c discharge" doesn't mean anything. I think they are trying to say that the max discharge rate is 49.5A.
That makes sense. I think what you probably have is a 3300 mAh 15C battery.
3300 x 15 = 49500 mA = 49.5A.
In many cases, battery makers overstate the "C" rating and therefore the maximum discharge rate. People who know a lot more about this subject than me suggest discounting the advertised "C" rating by perhaps 20% to be safe.
- Jeff
Old 11-22-2008, 07:44 AM
fishingkittyman
Thank you, I believe you are correct because someone else told the same thing. They gave me a formula that looks like this 49.5 amps = 49,500 mah divided by 3300 mah = 15, thus being 15c.
Old 11-22-2008, 08:55 AM
cyclops2
cyclops2's Avatar
Believe NOTHING in the battery selling world.
I & others have run tests on charging & discharging batteries & most ratings WILL destroy the battery way before you get ANY number of full power cycles.
I did 1 cycle of a set of batteries @ 10 C . Battery dropped voltage in 40 seconds from 3.2 V to 2.1 V and NEVER charged up to even 2.8 volts again.
Pure, bull crap, to sell the batteries. They did return my money when I sent the test result data back with the batteries.
The batteries were rated to do 20 C.
Rich
