GP J-3 ARF strut to wing attachment
PA
Folks, It looks like a flimsy set-up, ie. the directions for attaching the struts to the wings on the above Cub. Does anyone have a better idea? I'm looking for strength and durability. I was thinking of cutting a small plate of ply, countersinking it on the bottom for a blind nut, epoxying in the nut then epoxying the whole thing to the area on the wing. If the epox. goops up the threads, no sweat, simply run a suitable tap through it. I'll probably use a #4 socket head bolt into a #4 blind nut. Thanks Bill
RE: GP J-3 ARF strut to wing attachment
Yep - the strut attach points need some beefing up if you are gonna attach and remove each day's flying...
I did much the same thing using a #6 thread insert in the existing pads, attaching it with nylon screws that will hopefully shear off , "just in case"...
On another thread, someone also replaced the existing plastic attach tabs with coke bottle plastic - said it was a bit more durable... Think either that or some thin soft aluminum sheet might work...
Cheers!
Jim
Cheers!
Jim
PA
Are the attach pads on the wing thick enough to accept a threaded insert? Sounds like a good idea, and if they're thick enough to thread the inserts in, that's how I'll do it! Thanks. Bill
There are a couple of threads on this exact subject in the ARF section. Do a search on "GP CUB J-3" and you should be able to find them.
The two most popular mods are using pieces from a 2 liter coke bottle and making brass connectors, both which replace the CA hinges. I'm going to try the coke bottle fix when I get around to fixing my strut connections. I've gone through two full sets of CA hinges and won't use them again for this application.
Too bad GP put such weak links on an otherwise nice plane.
ORIGINAL: qcrcbill
The best solution would be to install a T nut behind the pad with a T nut, but haven't figured out how to do that without cutting open the covering on a rib bay
Cheers!
Jim
My Feedback: (12)
IL
I have the Cub ARF and I never had an issue with the strut attachment but then again I always left them attached to the wing. It's the CA hinge material that will need to be replaced, Mine broke after the 3rd flight.
PA
ok thnx I'll make that modification. What fuel tank do you all use? I'm going to use a 3 line system, probably about 10-12 oz. The supplied tank isn't very good. Thank you. Bill
My Feedback: (21)
NJ
I replaced the tank with a Dubro 10 oz tank and added a "holder" along with a screw in bracket to hold the padded tank assembly in the front of the fuselage. I do not like installing tanks by "press fitting" with a lot of foam.
