pull pull system
RE: pull pull system
Usually the wire is secured to a threaded portion which mounts to a clevis, which is attached to the control horn, to allow for some adjustment. That is the method I have used for a pull pull setup, you could just loop your wire through the horn and secure with a brass or other short length of metal tube that is crimped to hold the wire, but I would not do it like that.
When you are doing pull - pull don't forget about the Ackermen. http://members.cox.net/bdfelice/Ackerman/ackerman.htm
Here is some links to pull - pull:
http://www.geocities.com/roger_forgues/PullPull.html
http://www.mindspring.com/~rellis2/rcpattrn/ppull.htm
http://www.modelairplanenews.com/ME2...1F8759CD2BE46F
