Greases
Greases
<div id="post_message_2245958">What is the best grease I can use for transmission gears and heavy duty bevel gears? I heard black lithium grease is the best. Some have used white lithium grease. Or, silicone grease for plastic gears.</div>
RE: Greases
The last time i had my AX10 tranny apart i applied a small amount of Tamiya Diff grease. It is what i had on the work bench at the time.
Works fine with that. Use what ya got.
