Xicoy Turbine Telemetry Codes
I use the XICOY telemetry adapter to get the motor status on my Jeti transmitter. The turbine status is just reported as a number. I found this list of codes from Gaspar:
Status 0 = "TempHigh"
Status 1 = "Trim Low"
Status 2 = "SetIdle!"
Status 3 = "Ready "
Status 4 = "Ignition"
Status 5 = "FuelRamp"
Status 6 = "GlowTest"
Status 7 = "Running "
Status 8 = "Stop "
Status 9 = "FlameOut"
Status 10 = "SpeedLow"
Status 11 = "Cooling "
Status 12 = "IgntrBad"
Status 13 = "StarterF"
Status 14 = "Weak Gas"
Status 15 = "Start On"
Status 16 = "User Off"
Status 17 = "Failsafe"
Status 18 = "Low RPM "
Status 19 = "Reset "
Status 20 = "RxPwFail"
Status 21 = "Pre Heat"
Status 22 = "Battery!"
Status 23 = "Time Out"
Status 24 = "Overload"
Status 25 = "Ign.Fail"
Status 26 = "BurnerOn"
Status 27 = "Starting"
Status 28 = "SwitchOv"
Status 29 = "Cal.Pump"
Status 30 = "PumpLimi"
Status 31 = "NoEngine"
Status 32 = "PwrBoost"
Status 33 = "Run-Idle"
Status 34 = "Run-Max "
Status 35 = "Restart "
Status 36 = "Error "
I found the information above.
Status 3 = "Ready "
Status 8 = "Stop "
Jannica (08-14-2024)
